giutech
Sorry, after a period of inactivity on ugnx5, I returned to reuse version nx6 after a long period on catia v5, I kindly ask if you could indicate how to solidify a group of surfaces.
apart from you asked 2 different thingsis it not possible to sew the surfaces without getting a solid?
Tolerance you impose it as much as you want. if exaggerating, however, the obtained solid may not be corrected. the system "cuce" you also with 0.5mm tolerance, but it spoils the edges of the individual surfaces.surfaces must be in tolerance, usually 0.01 distance to get a solid.
But I don't understand, do you want the solid or not?
if "cuci" and the result has no holes, the system automatically converts it into solid.You're right, I'm new to the world of forums, I don't know how they work, however I'm jutech, I've been a designer, for about 3 years I've been working in the motorcycle design industry, specifically I'm working on c.a.s design, reverse engineering and design; What about other I am doing a passage from catia v5 with which I had a great practicality to ug, even if I already know it, it is at least 2 years that I do not use it and therefore I find myself dismayed. As long as you think it's an exceptional software!
is it enough as a presentation? Unfortunately I still don't have a personal site but I'm thinking about making one...
Then the questions are both right, at least in the casket I can do both...
I don't know if you've noticed I've placed a problem on the spline too!
hello and welcome on the forum,Okay, thanks to the suggestion, I did now, but it is not possible to sew the surfaces without getting a solid?
in the last versions it is possible.Remember then to return to set the body type in solid otherwise even if you do an extrusion of a circle turns out only the cylindrical surface (and you can't go back)
that strange interface that has nx ...:biggrin:, for a farmer like me used to work with that wax tablet that is proe :biggrin::biggrin:in the last versions it is possible.
is that nx has + flexibility of pro/e:that strange interface that has nx ...:biggrin:, for a farmer like me used to work with that wax tablet that is proe :biggrin::biggrin:
I think you and I know each other... It's like a feeling.is that nx has + flexibility of pro/e:
- can or may not make boolean in the extrude
- can create a solid or surface (and vice versa)
- can extrude with stripes (from the section, compared to a floor etc)
- can symmetrically extrude
- extrudes along a direction that may not be perpendicular to the section
- extrude curves that can be non planar
etc.
... so the input mask, to take into account all of these things is playforce a little richer.
Fortunately though, as you use it, nx stores the parameters used and proposes only those, closing the other options.
