MARCOC
good evening to all, if to someone and already happened to use the command in object maybe you will know why not recover the explosion lines. you do an explosion and insert the explosion lines, when in the upper axieme you do the explosive and you go to recover the already made explosion of the subgroup, I care the exploded, but not the lines of exposion
Can anyone tell me if it's normal or is it a problem that alone me?? ? ?
Thank you very much
Thank you very much
