reuse explosion of the subaxieme
MARCOC
good evening to all, if to someone and already happened to use the command in object maybe you will know why not recover the explosion lines. you do an explosion and insert the explosion lines, when in the upper axieme you do the explosive and you go to recover the already made explosion of the subgroup, I care the exploded, but not the lines of exposion
Can anyone tell me if it's normal or is it a problem that alone me?? ? ?
Thank you very much
I try to answer you even if I don't know the explosions and any drawing regulations on the subject...
The logic tells me that I in a higher order set is good to see the links of his compoent in exploded mode, not those of a lower order. that does not take away that the design tool should let me be free to choose what I want to show... I threw it there.
as a concept it is, but in the logic of recovering something already done no, as the lines on a subaxieme I have to replicate 2 times and therefore double work
