save image in scale contained in a .dxf file
  • Thread starter Thread starter volaff
volaff
Hello, everyone.
I have a .dxf file of the logo of the already scaled country region (it must be of a certain size).
How could I do to extract from the .dxf file a .jpg file of the logo image (with the same scale used in autocad)?
I don't know how to use autocad at all but I can try.
Thank you all for your help.
Good weekend.
fly
attached the drafsight print screen, but that of autocad is practically identical
1:1 is the ratio between the display of the drawing and that of paper format.
said in plain words, if you have a rectangle 297x210 and print it on a sheet a4 you will have a ratio 1:1
Thanks for the answer.
I have tried as you said, I have printed 1:1 but if I measure the size on the printed sheet they do not match the size of the measuring line.
Maybe I hurt something. I'll try again tomorrow morning. will be exhausted:)
Thank you very much for your availability!
tomorrow attach the images of the two dimensions and that of the settings of the print
below the pictures you suggested to me to attach and the printed pdf sheet.
I set scale 1:1 and "elements to print" I set "window".
I don't know if I did well.
thank you anyway!
But how much do you put it in the drawing?
where are those measures in pdf?
in my image, in red, the measure made with the tool of the pdf reader; is quite different from your
Thank you very much for the answer.
Perhaps my problem is precisely in export pdf. I explain better.
I attached the .dwg file from which to "extract" the only image of the logo.
probably when I go to print, setting the "window" item in the mold area, even if correctly imposed 1:1 scale, it packs all sizes.
At least I think.
thank you anyway!
the measures in pdf come out simply from the press 1:1 made of the .dwg file.
when the mold, if I go to measure the share of 86 mm I pick type 82 mm (with the line to tell us).
I repeat why I am not clear enough:
How much is the measure you detect in the dwg?
the measures present in your pdf, repeated 83 and 86, how are they made? with pdf reader? with autocad?
in the image below the property key you see a red line which means that the print is beyond the margins compared to the selected sheet; put center print and make sure that red line isn't there
Excuse me if I'm not clear enough in the show.
the measure of 86 mm was detected with autocad and represents the main measure regarding which the .jpg file of the logo was scaled.
in practice a .jpg file with certain dimensions, imported in autocad and scaled compared to the main measure of 86 mm in order to be applied on a fabric.
now this dwg file contenting the scaled logo should be saved in jpg or pdf to pass it to the embroiderer that will make it on a piece of fabric.
I don't know if I was clear this time.
If not I ask vein.
ok,but you are not talking about abyssal differences if you detect 82 with the ruler
Sure.
the problem is that the printing that I saw a print with precise quota measured with the proper ruler of 86 mm.
Now I'd like to see where the problem is.
checked and is already on 1:1 print.
Bah.
I'd say the problem might be me.
I try to print in pdf by handing out even more. Maybe I find the hole!
