sculpt tread with catia
  • Thread starter Thread starter oro987
How does your model behave with the rake effect? that is, if my design in 2d (i.e. on the floor) was a rectangle, after having "developed" it
how does it appear on the rubber model obtained? I explain better, the closer I approach the center of the toroid, the more you feel the rastremation effect, that is from a rectangle in plan I get a trapeze in 3d.:biggrin:
I don't know if I understand, I'll put you an image of the manual on the adagia function.
I meant any figure to spread in a toroid (e.g. a rectangle) how does it become on model 3d?
in the three drawings that you placed me it seems that the softw. Ask as you want the corners of stripes of the coves that make up the tread instead I want to know the bottom of these coves as it creates.
Let me know if I explained well:cool:
Perhaps I understand, if you have a rectangle say 100 x 150 and you want to react this rectangle on a surface you have to develop the section of the tire both in x and in y. (point 1 and 2)
just check the length of the sections and redesign them on the floor.
inside drawings the tread finally use the adagia function this function asks you what is lingombro and where it has to be undeveloped , this is the fundamental point if you change these values then you will have an uncontrolled/real spread, while if you respect the size of the developed tire (such as the example in video) the enveloped length on the tire will be the same as the starting one.
Will it be clear? Boooooh:
While if you have an image with size and these dimensions are the result of the projections on the plane the game is similar, I can make a video even for this if you want.
Just tell me what kind of video you could see if wmv or swf
flavio do not say booooo.. because I think you understand my problem perfectly: Finger: I put you a drawing so much to complete what we said hoping is clear. But you didn't tell me what soft. You made it. Thank you.
Bye.
I can see .wmv.
Now I have to agree, I apologize and I feel in the early afternoon.
thanks again and hello:finger:
Now I know what you mean.
the compromise I found is this igs
I practically projected the desired profile on the tyre developed long and then reacted the latter.
I'm practicing you, you understand.
now we have understood:4406: we say it is a good beginning. you kept the width of the constant banners and the rake made it in the voids i.e. between one and the other. That's good, too. if you try to reduce the profile radius should be more evident.
gold
thanks for the experience you made me do:finger: you never end up learning.
to conclude I wanted to have your confirmation and that is the tire is not developable on a floor?
if you consider how tire both the tread and the flank ie all the writings
that there are (measure. brand, etc.) I would say no.
but if you divide it into two parts, the first as a tread with design 2d that sends you the customer and the second with the so-called lettering of the side I answer you affirmatively. the advantage lies in parameterizing everything you can.
Bye.
an example next to the tread is that I attach you where I was authorized also because it was exposed to the last fair in Milan.
on the side there would be so much to say and do. for example to make a macro
giving a diameter you place the logo and letter characters per letter spaces included on that diameter and then the adagia (map) on the cheek.
Bye.
Bye.
Do you use the parametric?
http://www.omnicad.com/video/para-associa.wmv
in this field you are almost obliged to use the parametric because the measurements are different but the tread design is always the same.
compliments for the videos are very explanatory: eek:
but take away my curiosity. the softw. is omnicad version?
in this field you are almost obliged to use the parametric because the measurements are different but the tread design is always the break.
version 8 ready for end users only at the end of November.
returning to review the first footage of that fishbed tread that you posted to me earlier I noticed that in the rush I made an evaluation error. :redface: in reality those arrow-shaped figures you have made come out of the gum as full entities, instead in the rubber they have to be empty. to give you a more precise idea, I put a .igs.
Let me know if it is clear and if from the positive you have achieved in that example
you can also get the negative as in the igs that I attached.
music does not change, just change the direction of envelope.
I put your tyre in reverse :)
I made some modifications on the floor and I brought them back on the rewinded model, it didn't even bother about a thousandth.
I'll make a wlm?
ok:finger: I imagined:biggrin:
as you have noticed the most heavy task is to make all those surfaces in the plane and parameterize them. all this to do with catia. It's a challenge:wink:
Hello flaviobrio
Hello flaviobrio
capisco ! have good luck :wink:
