PiDezz
hi, I am new to the forum and so I greet everyone and thank early who will help me.
I would like to point out that I have little familiarity with proes as I use almost only the 2d (medusa4 adv) and therefore my problem could be a banality.
I have to do a simple pulley with 7 gorges, my problem is due to the fact that the departure I have on that central one.
Now, made the central throat quarry in revolution with the throat center positioned on a floor, I have to make a series for the other gorges, 3 on one side and 3 on the other.
I go to give the serial comendo, select direction, then the plan that goes to the center throat, type 4 as number of gorges (having three besides the original in one direction), then repeat all in the opposite direction.
to see everything ok, if I open the series, inside I will not have 7 features, but 16 as in the direction 2 I made 4 copies of the 4 features that I have in the direction 1.
doing some tests with holes on a plate, selecting perpendicular planes for the departure of the two directions, I understood the reason... .
My question at this point is, is there a way to make the series that I need without any copies of features going to overlap?
obviously keeping the start in the feature of center.
