anthony87
Hello everyone!
I am brand new to the forum and also new to the world of autocad (although I already have some experience ).
I describe my problem, hoping to be able to receive from you some answers that help me but I hope before everything else to be clear!
are in possession of a ".dwg" file that represents a cathartic cartography. practically it was taken the image of this cathartic card and then were polyline drawings, lines etc. so to have a real design of it on autocad.
well I wanted to try to establish some coordinates of it in the real world.
I installed both autocad 2014 and autocad map 3d 2014 for this job.
with autocad 2014:
- I connected to autodesk 360 online
- I used the " geographical position" function to establish the position in the real world thanks to the connection with bing air maps
so now I have bing air map below and above my cathartic card. bè is not very precise because of course how you will know the roads change and also the buildings (the charter is 1951).
But it is quite precise. There is an error of about 4 meters with the overlap is not so much. Although some buildings have an error of 10 meters with the overlap but it would be enough to fix them and it would be perfect to say.
the overlap is done well because I referred to a church that has never changed so it is just as I put the position.
now what I would like to do is understand how to get and view by clicking on a point of the map coordinates in sixty degrees.
In theory, it should provide them directly bing but in practice I do not see anything.
I have seen looking on google that to someone the coordinates appear below, but I wrote only "utm84-32n" (as you can see in the picture below)
In practice, it would be a kind of work of georefence even if not very precise, but for what I have to do, it would be good like this.
I should just figure out how to get the coordinates. How can I do that?
with autocad 2014:
