setting limits cat v5
  • Thread starter Thread starter Tatasala
Tatasala
Hello, I have a small problem with v5 cat. the cursor goes to snaps, in practice it moves every 10 units. How do I change this setting? Thank you.
I explain better, when I put the snap to the point the cursor moves every 10 units and I can't center, for example, the extremes of a segment.
I guess you're referring to the sketchy environment. . .
you have to remove the snap to the point: deselect the icon at the top right representing a grid with a cross,
if you don't find the icon you need to activate it, go to the menu\view\barre of the tools\struments of the sketcher (check mark).
or, in the menu go to tools\mechanical design\sketcher\snap at the point (check it), in that window you can also set the step grid.
