sezione custom
  • Thread starter Thread starter dario88
dario88
Hello, can you tell me how to create a custom section? I have to define a section of a beam 188 that is not present in the ansys database. thanks in advance... hello
once you create your keypoints and lines, define the real constants beam144 and the material. at this point to create your sections.
preprocessor
Section
beam
common transport
a window "beam tool, choose your section, give the measurements and id for the various profiles.
after created check them to the lines, through the mesh attributes.. Then you did.
ps: who is your professor of fem at the unit?
Hello I have a problem being at first arms with ansys. I have to do a modal analysis of a complex system, consisting also of cables that cross a hole. Usage workbench
the problem is that in the response of modal analysis, the deformed of the cable penetrates into the body containing the hole through which the cable must pass. or better the cable is not confined to the hole but goes beyond entering the solid that contains the hole.
How can I solve this problem? Do I have to enter a contact? or is there any option to "make the cable understand" that must remain in the hole?
raginbull unfortunately ansys workbench I never used it and I can't help you.:frown:
Thank you very much.
I have another problem, though of a different nature. By setting the use of the video card in the product launcher (3d), obviously in displaying my computer goes much smoother. the inconvenience is that when I then capture image, it gives me everything black and only the writing ansys. Who helps me? Thank you.
p.s. The professor is luigi iuspa.
