hi attached file ipt (inventor 2016) of sheet but does not develop because the face with 4 holes is not from 4mm but 3,99.
How to solve? Does anyone know how to rebuild the charged fold?
thanks and greetings.
bho, apart from the face you say, to me the size as 4 mm, what does not return is that in plate rule you set a fold=thickness beam, while in the model is 1 mm.
But it does not develop even putting the right value.
I see it is a derivative from another solid.
Was this made in sheet metal environment or what?
if it was made in the environment standard part, how was it obtained?
wait, to me measure 3.995 on the central face, the one without holes, and therefore does not develop.
or remove all the faces of one side (e.g. the external side) , those of the walls of the holes and the heads to the thickness so as to have only the outer surface.
in "default sheet values"put the right value of thickness and radius fold
then go into model and thicken with thickness=thickness, return to the sheet environment and finally make the flat model.
when you create a particular sheet from a solid derivative, you must always pay attention to how it was created, otherwise you cannot develop
