andreaf93
Good afternoon to all,
is my first post and thank you in advance for the help you can give me, currently I use sw 2016 and my level in design with sw is at first arms.
I designed a sheet metal with the sketch function, then I turned it into sheet metal with the function "basic flange tongue" giving the height I need and the required thickness.
I subsequently created holes with the "guided creation of holes".
Once I make the flat repetition and I measure the diameter of the holes rightly I see that the holes are no longer perfectly circular but oval in the side in which the displacement is carried out and so everything ok.
this flat repetition was also designed by another designer with the same odds and I value that his holes in the flat repetition are more oval than mine, moreover his are pentagons with more angles and sides than mine. (saying it in pentagons: in the flat repetition its oval holes are more circular pentagons while my are more hexagonal oval holes).
If I didn't explain well, please let me know.
of course specific that in the view 3d or in the planting the radius of the dizzying the thickness and diameter of the holes correspond.
Good evening
Good evening
