sheet metal
  • Thread starter Thread starter Mauri_c
Mauri_c
Hey, guys.
how do you "develop" the sheet using sheet metal and hopper command?
I made a hopper with the sheet command and I need the development. I have to make the table.
Hey, guys.
is not said to be developable. ...
do you have 2013 and have you used the appropriate command?
Can you post an image of the hopper?
a question...
Is it open somewhere?
In the sense, is there a "rip" that actually allows you to develop the hopper?
Yes, because after the hopper command, I used the flange command for the various folds and extrusion for various cuts etc...
not debated
I don't know how the command works (I have 2012), but if somewhere there is no opening, surely can't develop the sheet!
Okay, thank you.
development is very convenient x who folds the sheet. then this serves in carpentry, so if weld all the various sheets of sheet metal it is okay the same. .
Hi, Mauri.
I think, like mbt said, there's no "opening" in your plot and so the program doesn't make you explain. for this type of hopper I recommend you split it into 2 parts and weld them at the end, maybe turn a fold inside.
you can split it into the middle of the short side, or break it on the diagonal. . .
simplemtne is the command "separation" in the group "modification" of the ribbon-bar.
You can do all the folds you want, but if you don't open it, it will never develop.
Yes, apart from the due observations on the separation command, if I don't see bad, that moves all in a development is not there.
try to post the .ipt file..
