bez
Good morning, everyone!
I am new and I mean little mechanics because I usually do other things... so forgive my chestnuts and have patience :d
I have to design a system enlivened by a rack. the only two constraints I have are the speed of translation of the rack: v=100 mm/s
and the race that my enlivened object must do: l= 30 cm
I have done some accounts but I don't know if my approach is right.. could you give me a hand to verify its correctness and give me any advice?
what I thought is:
I choose a pinion with module m=1 and number of teeth z=70.
then the step is p= lazy* m = 3,14
primitive diameter d=70 mm
the rack has the same module, so if I want you to translate 30 cm the number of teeth that must have is 30 cm/3.14 mm = 96 teeth about ...
I calculated the transmission ratio as u= (2*pigreco) / (p*z) = 0.0286
then the speed at which the engine must turn: omega= u * v = 2,86 rad/min
What do you say? demolish me!! :
Thank you!
what I thought is:
Thank you!
