jim78b
I have a design only lines but I see that I have a lot of text styles that slow but I can't eliminate them as I do?
In the end I became mad_purge is not going?
If not, it means that somewhere in the design there are (a block even if not inserted, a layout, a layer turned off... )
and no that mystery !!! already tried with wblock nothing .che stress though.because they were not erasable but you did not find out:biggrin:
- - - updated - - - -I'm sorry if I've attached two times I've been wrong!If you can attach the dwg...
to erase these elements exist This is what I have*; in your case I used the acad_dgnlinestylecomp and acad_mlinestyle voicesprobably, as I have already written, is a style derived from xref.hi I prvato but in text styles there is a text with written $$ bad shape... What command does it delete?
post it, but you probably don't use the lisp wellListen I have another 10 mega file if the place gives me an eye I can't with the lisp to stream it and it's very slow!
I have the problem in this if I issue a block and I go out it takes a life to get out!!! I'm going mad.
