brikki86
Hello, guys, excuse me if I'm back breaking up and asking for your help... .
I was flying to ask you if you knew some setting to make sure that the command in question does not give problems...in the sense that, having to draw electric cables also bent, I wanted to use that command as an extrusion of a circle on a folded line, but it does not create a nice uniform cylinder, but rather a tighter sausage in some points and wider in others (you also deform the straight part). This happens to me at work, while a friend of mine is perfect... I attach the image of how it comes to him before accepting the change.
can it be that the problem is given by some settling? !
Thanks again guys!! ! ! !
Then I also put my "buckle" cylinder on it.
