grace46
Good evening, everyone.
having to simulate a path of candle milling (a 90° sharp hole) while performing a circular interpolation according to the z axis (in vertically penetrating gradually to the maximum depth, in the center of the circle arc, then symmetrical to the starting point), I used the solid sweep function.
I designed the tool as a rotation solid.
I designed the circle arch as a profile to be covered.
I designed a vertical axis as an intersection of the right and frontal planes.
when generating the solid sweep with the tool in the blue field, the trajectory in the pink field, follow the profile with vector (inserting the vertical axis in the field), the excavation is correct.
if, however, I exceed the depth of the conical part of the tip so that the cutting edge is constituted by the straight inclined to 45° and the vertical stem, the result is abnormal.
I'd like help.
attach a zip containing 2 rows: one with tool tip angle of 60° (which works only on the tilted cutting edge), the other with angle at 90° (which works on the tilted side and on the vertical one).
I'd like help.
