table list multilevel parts
  • Thread starter Thread starter ciobinn
ciobinn
Hi, I tried to do a search but without results.
I'm just using inventor.
I wanted to know if there was a way to insert a multi-level table.
I explain the result I want to get:
I have two a set called trave+column in which there are two under assemblies: beam; welded column (the column consists of real components)
If I go to table of the beam+column and insert the list parts, the table obviously returns me nr 1 beam - nr 1 welded column
In fact I would like to have:
1 - nr 1 beam
2 - nr 1 welded column
2a - nr 10 bolts
2b - nr 10 screws
2c - nr 10 washers
etc. .
is it possible to do it?
I found the solution:http://blogs.rand.com/manufacturing/2010/06/inventor-tips-and-tricks-expanded-structured-boms.htmlonly that now I do not understand why when I add the table parts and select the view
does not make me choose the distinct view comp. and puts me "only parts"
nb: As soon as you open the window list parts makes me choose the various options (structure-only parts-structured etc.) but as soon as they select the view from which to extract the data goes automatically in only parts and does not allow to change it.
the table returns all the components but not in multi-level style.
try to eliminate the distinct components and all the ball you put. at this point you can select the type of distinction you prefer.
