ciobinn
Hi, I tried to do a search but without results.
I'm just using inventor.
I wanted to know if there was a way to insert a multi-level table.
I explain the result I want to get:
I have two a set called trave+column in which there are two under assemblies: beam; welded column (the column consists of real components)
If I go to table of the beam+column and insert the list parts, the table obviously returns me nr 1 beam - nr 1 welded column
In fact I would like to have:
1 - nr 1 beam
2 - nr 1 welded column
2a - nr 10 bolts
2b - nr 10 screws
2c - nr 10 washers
etc. .
is it possible to do it?
1 - nr 1 beam
2a - nr 10 bolts
2b - nr 10 screws
2c - nr 10 washers
etc. .
