test in 3d in v6
  • Thread starter Thread starter p2000
That's not true. even with v6, if you want to lay texts in 3d details, you have to buy the appropriate additional modules.
Bye-bye.
I don't know what information you have but I assure you that in v6 with the simple mechanical package there is the possibility to insert 3d texts!
Bye-bye.
Hi, I installed the v6, it will be because I'm not using it yet, but I didn't notice that there's this possibility... Is there a particular command?
there is the "text" icon inside the sketch that allows you to quickly insert any text with the character and properties you want.
You're right, with this command you can... with the v5 version I did the same thing saving the text in dxf format that I then opened, copied and glued into the sketch.
p.s. are you using catia v6 after migrating from v5 of all files or started immediately with the new version?
