p2000
Is it true that with v6 they finally introduced the text command in 3d??
Bye-byeThat's not true. even with v6, if you want to lay texts in 3d details, you have to buy the appropriate additional modules.
Bye-bye.That's not true. even with v6, if you want to lay texts in 3d details, you have to buy the appropriate additional modules.
Hi, I installed the v6, it will be because I'm not using it yet, but I didn't notice that there's this possibility... Is there a particular command?Bye-bye.
I don't know what information you have but I assure you that in v6 with the simple mechanical package there is the possibility to insert 3d texts!
You're right, with this command you can... with the v5 version I did the same thing saving the text in dxf format that I then opened, copied and glued into the sketch.there is the "text" icon inside the sketch that allows you to quickly insert any text with the character and properties you want.
