thread cutter made with coolorange
graziano-g
I should draw a nut with a slit, build the nut, build the cut solid, apply the boolean subtraction together using the copy functions and sculpt but at operation finished the nut body is dissected while the thread remains whole... .
Any ideas?capture-20160401-221444.webpcapture-20160401-221525.webpcapture-20160401-221747.webpcapture-20160401-221822.webpHello, thank you
the thin face of the solid is bound to the floor passing through the center of the nut.
It doesn't work.. .
Did you manage?
Can you posterize the image?
solved, the solution is all logical sum.
the thread modeled first with the inventor tool (only graphically) then with threadmodeler ( physically ) is obtained in two stages.
applying the command sculpts in two times, ie first on the solid body then on the generated thread, you get the searched result.
capture-20160404-223221.webpcapture-20160404-223307.webpother solutions are welcome, if there are ....
