reggio
hi to all, often happens to have to perform fast studies or to sketch a new machine to present, creating it by making collages of various other pieces / assemblings, in those cases, it is not necessary, indeed it is a waste to create a clone and coding it, etc. etc., it would be much more convenient to take the model or the assieme, to save it as part and to be able to "stirate" to pleasure until you give it a form similar to give it to give it to the desired result, so only idea, so
If I were in 2d, I would use the iron command, when instead we find ourselves dealing with a subaxis, things become more complicated...
How do you do that?
in the example below for example I should widen of +100mm (50dx 50sx) dragging me around tree and bearings, perhaps without worrying too much about the angle of the changing conical, a stretch to give a maximum idea and have a footprint; in the next case I should compress, shorten of - 80mm (40dx 40sx)
how could I do in these cases and in other cases, without having to always clone and change everything?
How do you do that?
