maggico
Good morning to all, I work as technical help on board machine (a 5-axis working center) at a shipyard.
and from a couple of months I've been learning to use powermill: the results for now are satisfactory, except for one thing: having the ability to rotate the tool in multiple directions (according to the reference axes), I was trying to create a path where the tool has a 45° angle compared to the x axis, as in the following image
in fact, however, the output file (inform immediately of having inserted the correct post-processor and its .mtd file of the machine) does not present the rotation of the tool, unless In the preferences of programmes nc there is no work plan, relating to the machine with which to compare it with that of the path (so I think I understand)
My question arises from the fact that a colleague does not use to put this work plan in the nc preferences, yet his paths already go out with the desired orientation, obviously in the phase of creation of the path (and subsequent writing) we both use the same settings.
Could someone give me some extra information?
I also inform you that my colleague uses powermill 2013, while I use powermill 2020.
thank you very much for the courtesy
in fact, however, the output file (inform immediately of having inserted the correct post-processor and its .mtd file of the machine) does not present the rotation of the tool, unless In the preferences of programmes nc there is no work plan, relating to the machine with which to compare it with that of the path (so I think I understand)My question arises from the fact that a colleague does not use to put this work plan in the nc preferences, yet his paths already go out with the desired orientation, obviously in the phase of creation of the path (and subsequent writing) we both use the same settings.
