Camillo60
Good morning to all,
The subject has already been dealt with, however, not having solid bases of mechanical engineering I would like to go back on it to try to understand better what are the necessary steps in order to reach a solution that can be useful also to those who have difficulties.
this the question and the parameters at the moment available:
I have to gear a moving vehicle with 4 full rubber tires rotating on bearings. the flooring is rough concrete. the mass of the vehicle is 6000kg.
under certain circumstances, the vehicle will have to take a road with a gradient of 15°. the speed of the vehicle is not critical and can be set at only 0.5m/min. absolutely non-critical acceleration given the modest speed. a three-phase motor asynchronous + reducer all coupled to one tire (we prevent traction problems in case of poor adherence of the only "active" tire).
I would ask, if possible, to list the stages for the calculation of the various parameters and the relative formulas (simplified where available).
Thank you and I remain available to any questions.
Camillus
Camillus
