tree update or elements
  • Thread starter Thread starter Micheletecnospazio
Micheletecnospazio
I have a structure... composed for example by making an easy case from two elements... If I change the name of the child element... When I open the father, he no longer loads the child element. How do I make him realize he's the same name changer? I don't want to delete and add component... Of course. Otherwise you delete the linked body and then I lose operations like revolve and subsequent operations done... do I have to use replace in a particular way?
thank you for those who will have the opportunity to answer
I imagine you changed your name to file system: cazz@ta.. .
You have to open the assembly, save as the component.
in this way the assembly keeps everything.
if you have already done you have to replace.
I tried but maybe I'm wrong
I have to change the names of all files... if I save as of the first file and call it file1
Then I open the second file that contains the file1... in the assembly I don't charge the file1 (which maybe was called start)... turns off... .
you make me feel a niubbo which I am uahuahuah but this cad I use it for 3 months just not to judge me wrong..:biggrin::biggrin:
Otherwise I didn't ask for advice to the enlightened like you;-)
Unfortunately what you want to do on "file system" cannot be done.
However, in the design field, the fact that you name "a muzzo" and then change them, is not exactly a "best practice", especially if your model became "official", then usable and used in a lot of assembly.
I mean, I couldn't... ♪
We know it's a thing. but my work began with a very new research project for the company... we are still in phase of start up.. so even if it concerns official documents we realized that it would be better to adapt to certain different and more immediate conventions
Anyway thanks:biggrin::biggrin:
... and already that you have a look at the "versioning" of nx files.
even without pdm could be something that in perspective helps you.
I didn't understand anything about your message. Then I'll break this clone command tomorrow, and I'll deepen thanks. .
matrix already that you have a look at the "versioning" of nx files.
even without pdm could be something that helps you in perspective
What do you mean?? versioning... pdm?
do you refer to the future make current command? :confused::wink:
go to customer default.
simblies - standard site - part name version
... then... study.. .
I think there's a lot to study this nx7. has infinite potential... Of course, to use it, I'd say enough. I think it's necessary to study. . otherwise many hours at home trying... You have some guides I don't know... some basic command source for me... the desire to learn there is... but I don't find much around
I would like to become an ace like you or others in a few years::biggrin:
everything you can learn by yourself. nx is no exception... indeed, if you beat our heads you learn better and with + profit.
But if you have someone who teaches you, you do it a lot earlier: money well spent, especially if your tutor is good.
If I taught you, for example, you might consider yourself the lucky man on the planet.
I'm trying to answer.
Tell me if I didn't understand.
for your problem there are several solutions.
1st replace component (on assembly navigator go to your particular son to change and with the right mouse button ..... find .... .replace component.
2° save as .... (open a set make a work par of a particular inside the axieme and you can rename them to cascade).
thanks and excuse if I answer you only now...the problem fior roberto is then in later files that recall these new renamed files. . the ties and the linked body are lost... I'm trying the matrix solution to go into customer defaults... I'll try. I hope not to harm:wink:
