lucavox91
Today there is a brief tutorial on how to create walls for historical buildings with an irregular section, make them stratigraphy and drill them.
creation of walls:we proceed creating normal walls with a reduced thickness compared to those actually present.
at this point I refer you to the tristan tutorial about creating walls
http://ctrl-alt-cad.blogspot.it/2011/06/pilastri-adattivi.html As a result we create the various windows and doors on the walls. Of course, if we have the adaptive family in front, this will not present a hole.
creation of holes:we proceed by creating a second adaptive family that we will call "empty" (live imagination
to which we will have to give an instance of extrusion. at this point we will have to do nothing but create other architectural columns taking as adaptive points those of the edge of the window and giving it an extrusion such as to escape from the wall+architectural column.
Once the operation is done for all openings we only have to click on change--->cut and first click on the adaptive family applied to the wall and then on the adaptive family then positioned on the window.
in this way if we move the openings the model will be updated accordingly taking into account the holes previously created.
stratigraphyI press that this system works but presents some issues that depend on different situations.
variable layer on the outside:We create a new type of wall and associate it with all the layers we want keeping them within the delimiters of the nucleus. in this way the column/adactive wall will be given the material of the outer layer.
variable layer insidewe create the variable layer in the core.
we create all the other external layers.
at this point the columns should merge with the nucleus. if this does not happen you have to redefine the architectural column and immerse it slightly in the nucleus.
Fine
This was my first tutorial.. I hope I've been clear enough. Let me know if I have to fix something
Fine
