useful resources for solidworks users
  • Thread starter Thread starter re_solidworks
hi to all I created using the ral color table the material "powder paint". as a base I used the material "coperture in dark powder" which is found in s.w. then using the converiosne table of rgb colors I recreated all ral colors. I tested some materials and the powder effect does it; I hope to have been useful.names of colors in ita.
Say hello.
I learned in an advanced course time ago this method of binding, which does not overdominate together, serves when there is the need to bind an object that has more axes of movement. with this method moves only axis that selects with the mouse. I hope to be of help:.
link: http://www.youtube.com/watch?v=tigjxjnxday&feature=youtu.be
Hi, ivan.
but this type of mating also applies "online"?
in the sense if I have to move 1 axis mounted on another axis in the same direction, this type of bond allows me to move one of the 2 without the other moving or is only valid for "articolation"?
Hi, ivan.
Now I try and tell you if there's any difference I'll let you know.
Hi, ivan.
I can only make it work part by now, it's already happened in the past I seem to have managed to make it go... I have to think about it:... I have the text today and I tell you.
Thank you:
in practice I should be able to move the 4 compact cylinders without moving the 3 base cylinders (and vice versa)
you can make it ivan... use the force!!! (not the effort that I will not come to clean.... :mad: )
Thank you:
the only thing that with the advanced couple of distance becomes hard to achieve results:frown:
if you can do it somehow.. otherwise I continue as now.. I move one axis, the other compresses, and then I re-enter it... :wink:
go quiet that works great... Sure is not that performance increases and you become a picture... but at least you can see in realview that it is always useful. to the maximum the disabled (from inside sw) and nothing changes.
