useful resources for solidworks users
  • Thread starter Thread starter re_solidworks
Perhaps there is already but I have not found a discussion with this solution
to remove from configurations <a macchina=""> and <saldato> so that petr insert in the separate materials the name of the clean configuration proceed in this way:
go into options>property document>saving and remove the tick to </saldato></a>assigns configuration strings description.
now you can rename without problems
igo image (of 2015) and link of the page from which I read the solutionhttp://blog.cati.com/2010/09/weldments-.htmlView attachment 42261
Hey, guys.
is there a manual similar to that of the nobleman of the caty but, for sdw?
I've been here for 13 years and I've been struggling in the passage.
Thank you very much
for those who were interested and were not aware of it, to extract quickly and with criterion the individual bodies from a multibody part, for example to me happens for the tubes to be sent to the machine cut tubes, you can proceed in this way:
-create a separate cut (not necessary, but facilitates the result)
-rename one of the bodies of each single folder (eg 01, 02, 03....)
-Save the bodies with menu inserts>functions»save bodies or right button on the cut > lifts bodies-click on automatic assignment names (the names of the individual bodies of the separate will be recovered for which those you have renamed 01, 02... will be the valid ones while the others -can be deleted being copies.
-confirm the function
-The new parts will be saved in the same folder as the multibody part.
important: a body-saving function will be created at the end of the feature manager, so any multibody modification function must be placed above it otherwise it will not be propagated to the exported bodies
