v21
  • Thread starter Thread starter rinato
I've been using visi for many years, but this is the first time I can't make a move to the new release. It doesn't give me any reliance, too many variations I think are worsening. the mixture between visi and worknc did not fruit for the moment hoped results.
2d processing I find it much slower than the v20 that calculates in the time of a click.
How bad did he hold the profile attributes for the closed ones??
I didn't find any improvements on the calculation time for the evidence I did.
What happened to the past menu? which allowed us to eliminate unnecessary pasts?
maybe for many it made convenient to divide the map of the fast keys of the cad from the cam. in the sense: I with the v20 with the "or" button can do the offset of a curve if I am in the graphics area or postprocess a processing if I am in the cam navigator area. with the v21 instead I would be forced to put the cam operations on other letters... but I almost have no more available... and the combination with other keys type shift,ctrl,alt does not satisfy me because I should use two hands.
the cinematic simulator then, that before the July patch was really indecent. a forum user said well: you first build the piece that simulates it. even graphically it was not of my liking.
the graphical interface then of the cam has worsened considerably. have done well to put the icons vertically next to the mask of the cam navigator.. But they all look the same with an unfolded prevalence of orange color!!
In addition, when I insert a spindle and the tool presetting asks me to insert even the arising that I never used. Why can't I leave zero as I have always done?
Moreover now it is mandatory to insert a crude in order to perform a 3d processing.
then while calculating it also happens to you that it appears and then close by itself a dos window??
Another thing I don't want is that to calculate the crude after a processing, I have to pass from the crude anal submenu and the same goes for edita nc name that must be passed by force first from the submenu postprocessor. miles with the mouse!!
I don't understand how "offset limits" intervenes.
I'll let you know.
Say hi.
But that, and also to another couple of e-mails for minor difettucci, always of the cam. for the latter I spoke also in voice, they would have let me know if they solved. Boh...
I think I'm the one who enjoys the general line of thought and discovers the most curious things, and all that I don't understand.
or they lost common sense on the street.
I'll get them at the fair. :mad:
then: at the fair I had too little time to chat with the boys "not sellers". However I've been told that v2016 has welcomed customer suggestions of the last year. i.e. there should be no clamorous novelty, but refinements etc. and have revised a little the layout of the graphics of the upper area: I didn't feel bad, as a result.
should distribute in November.
my pc must have understood it, because visi decided, suddenly, that he lacked the library msvcr110.dll and after having let try to help line various moves, I had to create a new installation, resigned to having to reconfigure everything again. But the new one solved what the old man needed. and then they say that mathematics is not an opinion. . .
Excuse me, but November this year?? So, rel. 22?
Well, I hope so...
and above all I hope to find the time to go to the presentation (but I will see little).
Good weekend.
