locky_77
hello to everyone who already uses visi 19? How is it? Any news?
This is underintensive. However the cam works a solid even if it is "partially closed" or things like that. the versions that turned on nt were more delicate in this aspect....
However I don't know what you work with the surfaces, of course it is that if you have to go in milling it would be better in the end to get a complete solid not to give possibility to the cam, whatever it is, to have problems.
I would ask you not to use the capital: That's screaming, thank you.hello to all , I use visi 19 since I changed operating system passing from win7 to win 10
I have found a problem has stopped working the wire of the cam, a video error appears to me with written "the chosen import library is not available", yet in the directory of the sistem files of visi there is everything! to someone and already happened and how did you solve it?
thanks to all
No problem, I hope you find solution to your problem. I can't help you. ☺I have not read everything in the rules, I humbly apologize!
hi, from a certain source on w10 was not certified visi21, let alone v19.hello to all , I use visi 19 since I changed operating system passing from win7 to win 10
thanks to all
