riccardot5765
hello to all, indeed to see us again.
It's been a long time since I've been writing, but unfortunately all a series of commitments have kept me away from the forum that I'm going to repeat.
I am evaluating the possibility of buying rhino to use it in the ship. I tried the program by a friend (who uses it for rings and precious) and I find it quite intuitive, but I don't know if it's for me.
In practice, obtained the hull from the curves as surface (which I can do) I also manage to place the lines of the various wallpapers. the problem is how to double these lines, that is to make an offset without deforming to the edges. I have no problem with longitudinal extrusion. other problem is then to obtain in each wallpaper the housings for the longitudinal assembly that must run from bow to stern. I practically have to get some passes for courses that go from bow to stern following the lines of the famine. Finally, as I convert the wallpapers obtained as solid surfaces, I would like to know if it is possible and how to pass it to a cnc mill, in the sense if rhino previews that option to generate the right files.
So much to understand, I should get something like this:
