welded tubular frame.... cutting table not updated
  • Thread starter Thread starter CRAZYMAD
I strongly disagree using automatic update if welded are used in large assemblies, for performance are heavily penalized and keeping the updated folder manually is simple.
Good to know!
I didn't know it slowed down the sitema automatic update. .
"deflaggo" then. :
Thank you!
Yes, but the size of the cut didn't put it on me, I had to put it manually on the flat profiles as threaded
Anyway tomorrow I send you the files prt and dwg
If the elements in question are extrusions, there are no separate parts of the cut
It is not true, the separate cut includes all the bodies, even if you do two equal extrusions and then change one, making for example a hole, the distinct consider them as different bodies.
the difference between structural elements and it is not the data of the cutting distinction of the first are compiled automatically (depending on what the profile of the specific structural element contains).
solidworks does not have the power to invent the things contained in the user's mind, but returns what is required to return; a structural element that is based on encoded reference files can be customized, an extrusion that has no reference file should be managed locally.
