reggio
hi to all, especially in these periods of absence forced by the work of colleagues, and telework, I was wondering if a wi-fi touch screen in the workshop instead of classic printed sheets could be a valid alternative and that allows the editor to consult the assieme or subassieme directly, without the intermediation of the designer who, in some cases, could also refrain from creating some views or classical sections replacing them with explosives "
I thought you could use a 15" portable touch monitor (€2/300) or a fixed monitor (and uncomfortable) 21" (€4/500) connected via wifi to the folder, so you can consult remotely/workshop, if the thing worked, the expense would not be excessive and passable at least to test the practicality and duration of monitor/tablet in the workshop..
after the monitor connected via wifi (which does not break to the 3rd manata ..) would be to test the ease of searching and opening files and the practicality in zoom, rotate, explode, compact, select ... in this, that you know, Solidworks have swiluppato in the latest versions, some app, plugin or other help What do you see in this sense? (I searched but I find little or nothing interesting) or behind the monitor/tablet must always be behind a dedicated pc/workstation?
any of you have already traveled similar roads and would like to share the experience gained?
