wildfire 2 compatibile con windows7
  • Thread starter Thread starter filomens
filomens
Hi, I have a little problem to solve. I need to install pro engineer wildfire2 on windows 7. at the start of the installation does not recognize me the ethernet network card or wi-fi(to take the host id and create the license file). If instead I connect the pc to a wireless network for example, it gives me the id host and I can then generate the license. Did someone have my own problem? How can I circumvent this obstacle? in practice if not connected to a network tells me that the device is disconnected and does not make me work a bump. I hope you can help me.
I fear that proe wildfire2 cannot be installed on win 7. already with windows view you have the same problem.
to work but only if I am connected to a network. if I'm not connected it doesn't work as it doesn't recognize the network card. I would like to circumvent this obstacle because in these conditions I can only work if connected to a wi-fi network. and if I'm unable to connect as I can do? If there's someone who could help me I'd be very grateful.
You could try installing a new network and bridge. In this way you should be able to fool him as xp sees a bridge as always connected. Of course you don't transmit anything but...
wf2 is not certified seven ... so some problem you may still have.
the problem of network cards I think depends on the sequence of the same.
I understand you have two cards, a wi-fi and an ethernet.
First of all... is not the wi-fi card disabled for energy saving?
Do this check and then let me know, otherwise we try another system.
I tried popping up this property but it doesn't go anyway. the w5 version goes quietly. However I can only use the w2 if I am connected to the network.
you probably need to connect the wired network card to a router, otherwise windows do not activate the netowork and keep the card off for your purposes. I had something like this with xp, even though we were trying to do anything else: to mount a local disk as a network unit. even if the disk was inside the pc, the thing was possible only by connecting the network cable to the router, otherwise the network features of windows were inactive.
on windows xp 64 I did so, try with this procedure and let me know:
open "regedit"
hkey_local_machine\currentcontrolset\services\tcpip\parameters
"disabledhcpmediasense" sets: 1
(if there is no such thing as dword)
hkey_local_machine\software\microsoft\windows nt\currentversion\networkcards
put 1 key value ("fold") of the primary network card for server licenses (and a higher value for others).
(in each folder there is the "description" value that says the card model)
remove the flag "allow your computer to turn off the device to save energy" in:
- open "peripheral management"
- select the network card, dx key and "properties"
- move to "energy saving"
after doing the operations restart the computer.
Thank you very much for this information. through this procedure I managed to turn pro engineer w2 on windows7 and especially thanks to all of you I managed to solve my poroblema.thanks to heart!
I followed the procedure but I keep having trouble installing proengineer wildfire2.
the program resides on a dvd, arrival to the set-up and from there nothing happens.
set-up doesn't leave.
Do I have to copy all the contents of the dvd on the pc?
with the same program(dvd), on the laptop I had no problem.
do you have the same operating system on the 2 machines?
No.
on the door(where it works) I have windows view home with a 32-bit operating system.
I have windows 7 professional with a 64-bit operating system.
No.
as a rule you must have the 64-bit installation package, the 32-bit one can give you problems ... and then it is not said that functions, it is not certified or for view, neither for seven
I thought if it was good for 32, it was good for 64.
Thank you 1000!! ! !
from wf3 onwards you can install 32 bits on xp 64 (for example).
to install the wf2 32 bit on a 64 system you have to use a make-up.
install it on a 32 system, cover the installation folder on the 64-bit machine, open the bin folder and ptcsetup launches.
on xp 64 to me it worked, try on seven and let us know.
Wait, wait.
I want to see if I understand.
we summarize:
on the dvd I have pro 2.
install from the dvd on the porter (32 bit) without any problem.
with the same dvd on the fixed does not leave the setup.
So you tell me, the installation folder that resides on the laptop on the fixed and launch the setup.
Okay, but I'll cover the proewildfire 2.0 folder or what?
once you have installed it on the 32bit machine, cover the folder in which it was installed (it should be something like c:\programs\proengineer 2.0) and paste it into the 64-bit machine (you can also put it under c:\programs)
Afterwards enter the subfolder c:\programs\proengineer 2.0\bin e lanci ptcsetup.bat
