FlyHagoromo
Good morning
I would like to insert an embossed writing on a curved surface, in the area indicated with the arrow in the image. I tried writing in the drafring environment the writing, saving it in dxf format and then importing it into my file in order to extrude it later. but the extrusion is made starting from a floor, so it has different thickness on the curved surface. I would like the extrusion to follow the profile of the surface in such a way as to have equal thickness. I use the version of catia 3d experience, so if there are other modules of the program to use, there is no problem.
Thank you for your help. Good day
