wrong detail?
  • Thread starter Thread starter ¶Matteo1260
¶Matteo1260
Hello everyone,
Recently I was told to reproduce the attached design, a locking equipment for turning and milling, a doubt that protrudes me is the particular 5, which from the text seems a bushing, but does not come back because of the sampling.
Thank you!
What's wrong with sampling? do you think the bushings have a specific sampling?
the particular 5 is the main body of the equipment, it is clearly seen in section c
the main body of the equipment is the particular 1, if not, the ball pulls at the bottom is the sampling would be all wrong.
I was wrong with the answer.
is an incomplete design, in fact lacks the view of section c (which must be somewhere), lacks a view in the plant (which may not be in your text)
the two threaded holes in the upper section where are they?
component 5 could be a half shell that serves to close the tool; in the section to it is seen that the upper part has a slightly staggered hold compared to the lower one.
always looking at section to component 6 should be divided into 2 half having the opposite section; this would make use of the assumption that the main body is also divided into 2 and therefore composed of component 1 (lower) and component 5 (superior).
the two upper threaded holes could serve for lifting.
the director of the pallino 5 stops before due, must arrive until the mouth fixed by the tcei vines, is an error of the bocia that made the design.
hi body, from section a-a is divided into 3 parts.
part high part.5
part media part part. missing number (where is the pin part.9)
part low part.1
Hello Matteo
What should you do with that design? produce a 3d inventor? extract some details and quote it? or simply "copy it"?
Perhaps the answer is precisely in the task that assigned you the professor
Hello Matteo
I have to produce a 3d and explain in operation, the only thing that was not explained was the 5. I at first thought it was wrong the arrow, but now reading the comments, I convinced myself.
Thank you very much
