Brethil
hello to everyone, I'm sorry for the french but I'm really desperate!!! If there's some pious soul that can enlighten me,
thanks in advance to all
for work I deal with cooling towers, ie cubes of
plate filled with c needles, sheet metal panels etc...
use inventor 2011 for about 6 months and are self-taught; I am single user and therefore do not use the vault, my projects are in local folders,
I do not use ipart, because they are not sufficiently prepared and
I create every part from me, copying it in the various folders
project whenever you need the use of the same part
for more orders.
said that, when I am working on the file together for
realize the above cubes... I find myself in the stakes when I have to:
copy, mirror, serialize components, lower
level....inventor kneading me; instead if I don't give anything to these
things and place every time the parts and win one by one goes
everything smooth...because I can not use peacefully sti instruments
that would long halve the time of escution? ? ? ?
I'm probably missing something background, which I might know if
In the company they made me take a course... but here..nisba...sigh!!
It's not over...
a complete tower has something like 2500 bolts, as many dice and
double the washers... once you place the parts
(opportunely copied from the center contained in my personal project folder...x es "bulloneria m8")...if for example I dare serialize x type 15 holes, a screw, a bolt and two washers already bound to the first hole...the cursed is kneaded!!!...and yes I have 6giga ram and a nvidia picture fx1800; of course I do not create shuttles or only physical simulations.
the drivers of the video card are certified, inventor 2011 has the license, the pig goes from god except inventor...insomma..I no longer know how to behave. . .
I repeat, I could also ignore basic things, only from "self-daughter" :wink:...I don't know how to distract me, to make files *.iam maybe less heavy and difficult to manage. . .
Even to lower the level of some components to create sub-axis in order to lighten a final set, it is practically impossible. ..uffa!!!
any advice to give to a poor self-taught??? ?
thanks to all in any case
for more orders.
It's not over...
