funnel on cylindrical solid
  • Thread starter Thread starter Giacomanu
Giacomanu
hi to all, I have a small problem, I have to make some funnels of about 3 mm deep, rectangular shape (10mmx5mm) on a cylinder thickness 1.5 mm with diameter 130 mm high 30 mm. I hope to have been clear, by the way I use nx 6 in Italian. thank you all in advance for the solution.... hello
Is this cylinder a closed or wrapped pipe?
hi, it is an extrusion of a circle of diameter 130 mm high 30 mm with thickness 1.5 mm. (it's practically a pipe cut).
Hello and thank you
In reality, how is it taken?
Couldn't it be a flat sheet and then rolled?
If you tell me the production process, I'll give you the solution.
no, it is a cylinder with various shapes (made with lathe to plate), which then we put in the press and with a mold we make these funnels.
Thanks, bye.
Also I can ask you another information, I imported a file in iges, I closed the various faces, I sewed them, but remained a set of surfaces united, I would like to close it solid, how do you do??? Thanks again
hi, nx user, regarding the funnel on cylinder I found a solution, and it seems pretty good, I created the funnels making parallelpipeds and cut to thread of the outer profile of the tube, and then I used the command "emptying" and so I got what I wanted, I still look like your answer, that if in case it is a different method, it is all to learn..... thanks for the collaboration
hello and thanks again
In this case you must use the 'solid punch' command.
hi, before finding the solution I told you before, I tried to do it with the command you suggested to me (I have nx in Italian and the command is called "solid punching") but I couldn't do it, in my opinion it is possible to do it only on flat surfaces and not curved as in my case it has to be made on a cylinder..... or maybe I'm not able to find the right way... but if you tell me that it's possible to do it on a cylinder I try to make other checks.... thanks again...
thanks matrix, but here in the company I can not access the video, we have "youtube" forbidden-locked......
thanks matrix, but here in the company we have youtube blocked......
to cini that we are in the era of web 2.0 and if you expect to move on the companies through pigeons travelers, the process becomes long...
Try to see it somehow... If you need... otherwise patience.
Thank you very much.... I will look at it at home.... thank you anyway and good weekend.. .
hi matrix, now I saw the file.... thank you very much, as usual very precise and exhausting... hello to the next
I think we use it pretty well... even if again (but I don't understand) we are working with nx 6 when instead we have the following versions, but he says (but I don't want to inform if it's true or not) that we can't install them, because the teamcenter is not updated equal..... I don't know it and I don't even care.... anyway with nx start moving me better, even if at times I have to ask questions here in this forum, and fortunately receive criticism. .
hi and good work
hi and good work
I'm glad things go. . .
Yes, actually tc/nx are to be upgraded************ in the same step.
nx7.5 is supported only by "unified" type tcs. .
I do not remember your (which is tc express) to which it was aligned.
find customer support slow or give evasive answers?
You know, they have a job... that is to support users, not to do training. . .
sure if you open a call as you opened this thread here the answer will be "do a course or call a consultant". .
this forum is beautiful because the experiences are many and varied... I also frequent others, but at the end I always come back here, because I feel a little like "at home".
