gnome-rhone 14m mars
  • Thread starter Thread starter Er Presidente
Okay, but... and the compressor?
and the compressor go to buy it in hardware, of those to inflate the tires, that to do that of the gnome they serve the drawings :rolleyes:
You don't think I've forgotten that we've been playing until now and that to be serious, they need those good drawings, huh? :tongue:
I know you need to contact the contact you didn't contact...:mixed:
the crew has already been thinned to the minimum union and I want the increase if not, nisba...
and the compressor go to buy it in hardware, of those to inflate the tires, that to do that of the gnome serve the drawings
No answer...:frown:
They dare not answer me!
I'll send an autographed "note" of my swan.
p.s.: compared to this with the French, the diatribe with the india will appear a Sunday trip!
No answer.. .
dare not answer me!
a new version of "de bello gallico". :wink:
However I, as the only worker of the company, want the increase!:bekle:
p.s. with this are 3000...:redface:
absolutely single pieces as distinct, then groups, after having decided together how to structure them.
On the contrary, we could even throw down some ideas because we all have more or less "pasteggiated" the "monster".
Anyway, I get it, but you have to do all this good man alone? !
Where did the rest of the army go? ! !
Should I come get you?
a piece of the army was giving itself to do (silenziosamante :smile:) to control, produce the relative tables, translate into step and pdf (2d and 3d) the material produced until now.
I have put in "models_released" everything I have baked until now, I have also made the individual tables and I have also allowed to realize the dir. "drawings_released" (and mo arrives the caxxiatone) to put the relative pdf 2d.
I preferred to do this so that I could "close" the parts done until now and then devote myself to something else.
Are we sure the compressor really needs it? :biggrin:
Have you talked about the fourteenth? :biggrin:
I'm going to check. . .
"We're sure," is that all? Or would you rather take care of the heads?
choose you...
:cool:
14th? You don't even get to the third week. . .
He doubled my tots, so if I first took a "nothing" now, I take two "nothings".
these are satisfactions. . .
All right, just because you're my commodor, three tots!
Okay?
But we do not exaggerate with these demands, patience has a limit!
:cool:
it is important to finish the planche of the cams (what is it, there?) because it is fundamental to the coupling motor/reducer.
then would I like to know if ours has the triple helix, variable step or, bipal?
However, it would be a matter of reorganizing ideas about who is there and what he does.
who is ours and what he intends to do.
I mean, do I have to do as well as the slave underpaid the director of extra-subpaid jobs? :biggrin:
As you may have noticed, on the propeller I always "glysed" just because there were dozens of different models for attack, type and command of the step.
:biggrin:
summing up, radio completes the cam group, exatem along with marcof the compressor.
:mixed:
that from the sections and tables on the manual can be done, with some approximation to the usual on the casting parts.
you have to make sure that those who have them cast the drawings, otherwise with only manual all that is behind the central carter, you can not do. How do I say that?
Also for the heads serve the drawings, otherwise it is a pure fantasy exercise, and it is no more fun :smile:
We must suspend all the modeling work and give ourselves in order to recover the drawings, here at the piaggio, in france, in russia, in lungs to the north pole or wherever there is trace. :mixed:
You can see that you are not used to working in a healthy Italian company! you are accustomed to contest the constituted authority and to consider each order cpme a suggestion, you see...
and all, to each one his cross...
All right, I'm going to the French embassy, which I have to do, take a couple of maro's (I'm gonna die in French? boh) and I hide them in the cellar and then you see...:cool:
