MassiVonWeizen
the extrusion with the cut is the first thing I tried seeing the sketch you had done but according to me it is 'na munnezza (although equally acceptable) because it is a flat function while that profile develops on three directions.
You can make more cuts but remains a witness somewhere.
use the loft, which even if it is not accurate (and you can't know it seen the design you have in hand) however use a function not everyday use and you can try to compare the results by changing the various options of the profiles or the guide curves
