meccanicamg
the interpolation at times should be done a little by eye, with proportions etc. is not that you change the value abyssally.I managed to interpolate the data of the first stage (beta=15°) regarding zp=17 and zg=64 but I can not attach the excel file because the file format is not accepted... I have two doubts:
1) results are very different from expectations as the lower and higher values of wheel teeth are 55 and 135
2) how do I interpolate the data of the card with beta=10° if the reference values are missing for zp=17?
with the interpolation I have to fix at least one of the two variables (zp or zg), I could succeed with the second stage zp=21 and zp=37
p.s allego il file pdf
for j use the curve I gave you that you need to know z what you're calculating.
