meccanicamg
finally after 38 post we have the complete explanation of formulas and comments useful for the solution of the problem.Good morning, everyone. I tried to make two accounts.
first, when the cart advances to the left and encounters the obstacle (in this case, the rock), a force of inertia equal to mcarrello* acceleration that is applied in the center of the system.
This force appears every time the system undergoes changes in speed, as in this case (because before the shock, it advanced at a certain speed and after the shock, it is totally firm and tilts).
as he said News You must find the acceleration.
We write the equation to the rotation around the rock.
(f. weight)
(f. weight)*g*x- (f. painted)*g*y - cart mass*ccel*z =0the terms expressed on the left of equality are moments where:n.b.: ho considerto positive moments that make the body rotate clockwise and negative those that make the body rotate counterclockwise.
- the moment of force weight is such as to keep the vehicle on the ground;
- the moments generated by the force of thrust and the force of inertia are tipping (that is, such as to turn the vehicle);
after that, we put the acceleration as unknown I and thus we estimate its value to overturn the system.
accel =[F.SPinta*g*Y-F.Peso*g*X]/[Massa Carrello*Z]where:
f.peso = cart mass = 200 kg;f.spinta = 50 kg;g = 9,81 m / s ^ 2 (gravity acceleration);x= horizontal distance from the center of gravity compared to the stone= 730 mm;y=vertical push distance compared to the stone= 1800 mm;z=vertical distance from the center of gravity compared to the stone= 1600 mm;by inserting them in the above formula we get/stimulate acceleration.
♪[200*9,81*730-50*9,81*1800]/[200*1600]accel=1.72 m/s^2View attachment 68444
