(autosez 2) soil sections and profiles - automatic extraction
I zipped it because it made me mistake on the format... it's an mp4.... but now it gives me another mistake.... .
immediately after clicking inside the finca.. .
in the footage the block takes place after the selection of the profile polyline... However it doesn't seem to recognize the visual lisp functions, I don't know what to suggest if you don't try a autocad repair.
good evening to all, after downloading autosez2 I uploaded it to autocad using the appload/content/add new command. I restarted the program and at startup typing asez on the command line does not work. Where am I wrong?
probably doesn't appear at the start of autocad because you have to make another step, or you have to add it to the "starting group", always from the same window from which you called the lisp initially.
hi gp, compliments for your quarrel, although I still can't use it.
I have a 3d level curved file, I define the section line, but an error message appears:
the section line does not cross lines or 3d polynile entities.
but instead they are polyline 3d
What did I do strange?
Hello javier, the section line you draw is on the layer "sections"? (if I don't remember badly if you have 3d entity you have to put the section line on this layer)
1635332593373.webpI made a 2d polyline from which with as-profile I extracted the profile represented right, then with as and the settings of the previous image, I get this:1635332727151.webpCartridge only reports the number of pickets and not other information.
@javier75 You put a problem, we answered you in two, you gave no feedback.
Now you come out with someone else.
Perhaps it would be enough to take a look at the autosez help, but you don't think that if you attach a dwg with some objects we can, trying, understand something?
I had solved the first problem independently, and attaching the autocad mask I think I have responded to the suggested settings ... otherwise I ask for veia;)
in mind there are so many things, but by attaching the images I thought they were exhaustive, I attach the file. Thank you.
I can't replicate your error, it works regularly to me. . .
Thanks, I'm trying to do more evidence. the error consists of not displaying the complete cartilage, but only of the first row.
in the meantime you want to take advantage to ask how you can directly upload the applications to autocad startup, without using every time _appload
as further attempt I tried the lisp on other pc where I installed the same version of autocad and on the latter it works well.
This makes me think that the problem can be in some setting of the pc or autocad.
