MassiVonWeizen
so the parts were already placed in that way in the original axieme, so your original questionthen that subaxieme was born from a larger set in which I selected the parts that had to become subaxieme with ctrl and then I made "create subaxieme here"
has the answer in: because it was placed like this.displaying the plans of the set, gives me for example as the right plane this tilted. . .[...]Why are you doing this to me?
insert components > select the component > from confirmation.I would like to understand from you how to insert the components so that they do not come home
the component will be placed with the origin and the plans corresponding to those of the axieme.
this for the first component that will be the fixed one and that will command the orientation of the assieme, for all others that will be bound between them you can use the drag from the explorer folder or other methods
