Fulvio Romano
I took a look at the exercises... it seems really powerful to me!
I also used caelinux2009 (I recommend that you switch to the 2010 version that has just been :winkBecause I've pulled opencascade out to ask for something:
when I use linux cae (I installed caelinux2009) I can't open the step files. It tells me that I need to install the opencascade libraries.
Can any of you help me?
Thank you very much
Turns out...Hello everyone,
after progecad2006 made me kill for the umpteenth time under win7, I uninstalled it and tried all the cads mentioned in the thread.
There's no one who saved himself!
the only ones that touched the sufficency were planted. . .
I don't look for great things, a clean 2d that opens dxf and dwg and maybe allows keyboard commands, autocad-like. . .
I ask too much!? !
Greetings,
Canister.
Yes, keyboard controls are a nice thing that only have autocad and rhino.has a good impact and commercial-use license is ok.
However, it is very dissimilar from the autocad setting and there are no keyboard commands; that for me I use them by autocad 9 is a must-have;-)
Now I have on draftsight, it doesn't seem bad at all, but I don't want to say it out loud :-d
Canister.
It works a little weird... I try to explain. automatically when you download doublecad they give you the pro version (if you start using that don't worry when the thirty days expire you activate the free version). If you want to install the free version right away you have to go search through the downloaded folders and you will see that you have both the pro and the free one, from there you can choose to install the free without going through the pro... hope it is clear I also find it a somewhat strange way but obviously they keep you to get to know their version at a fee. . .I tried to download, following the link of ezio, the free version of doublecad, but it is a "pro" version that lasts 30gg. I tried a second time paying great attention to all the steps, but the result was the same. exists or does not exist a truly free version without expiry, and from where to download it?
I tried it, however and it opened correctly, although very slowly, a 2d file, little heavy, in dwg 2010.
the same file with wincad, which I had downloaded long ago following this discussion, did not open it.
confirm, it is better to abort the installation to This is point, then launch setup.exe from xt director (and not xtpro) where the file has been decompressed doublecaduniversal_v3.exe from 200 mb above.if you want to install the free version immediately...
