get fast dxf from sheet metal parts
  • Thread starter Thread starter flaminio
should depend on the setting of the stairs of the views.
the main scale must always be fluffy of the sheet otherwise if they do not match the export will be distorted; different views from the main scale are automatically scaled the factor between sheet scale and view scale.
In the meantime, hello or similar approach.
the scale setting modifies it in the sheet format.
do the tutorials that are best
Good morning, everyone! First of all, jenuary I want to thank you 740000 times because you are the salvation descended on earth! then I wanted to ask you, can you set as directory a folder that takes the name from the axieme from which the macro is launched and inside put directly all the dxf or at the most I would recreate a subfolder where there was a subaxieme? ? ?
or, to overwhelm, a macro will do all that described above and also carry all the pdf files of the table masses you find? ? ?
I swear if you can, I'll make you a golden statue!
from the axieme from which the macro is launched and inside put directly all the dxf or at the most I would regrow a subfolder where there was a subaxieme? ? ?
Hello is not clear to me the last part, would you like a subfolder with the name of the subset which contains the sheet?
for the export of the boards in pdf I do not see any problems, I would like to understand if it is done at the end of the launch of the macro of creation of the dxf, and then of all the files of the folder of the assieme or only of the sheets exported?
Good morning, jenuary,
Suppose I have a "a" set, and this contains a subaxieme "a1".
the macro will create a folder called "a", which will contain all the dxf (for sheet metal parts) + pdf (for all parts) of the components contained therein, plus the subfolder "a1" which in turn will contain the dxf + pdf contained therein.
all this leaving out thicknesses and materials.
I hope I've been clear.
Thank you for your availability
Good morning [U]jenuary[/U], I'm using your macro and it works great. As I have no idea how to change it I would like to know if it is possible to export dxfs in the same path as the axieme, as it happens now, but simply within a folder named dxf and in addition I would like the dxf to be called as the part without the extension and name of the configuration. Thank you very much!!! !
Good morning.
the macro works, but it only exports me the active configuration in the axieme, and not all those present in the part file.
Am I wrong? ?
by changing the macro, all configurations must be cycled by exporting them, currently export only the active one.
in this discussion we have created more versions of the same macro, in case you have to make the change you have to identify which to change. I have not kept any, they must be discharged from the discussions and modified
I do not know unfortunately at my expense the vba language.
would I ask you too much to change it?? I would be useful in some jobs, where I use the convenience of tables to create different configurations of some files.
I have one with 150 configurations, but it's a 30 mb file and I can't load it!
Good morning to all,
the macro works perfectly and exports the lines of the piece and the lines of the fold, in order to be able to insert the design in the laser cutting program I need to put the lines of fold on another layer so that you can assign it a processing nothing and not cut even along the fold line.
What macro values do I have to change?
