jenuary
you need to check on the mapping file if you can move them to the layer you want.
question:Can you attach a screenshot of those entries?are rumors that I have found already set in solid
are settings in solid, those you have are the default onesI think you associate them directly when you go to make a folded piece and make a folded edge on the base extrusion side of the piece or on the opposite side.
Good morning, jenuary,Hello is not clear to me the last part, would you like a subfolder with the name of the subset which contains the sheet?
for the export of the boards in pdf I do not see any problems, I would like to understand if it is done at the end of the launch of the macro of creation of the dxf, and then of all the files of the folder of the assieme or only of the sheets exported?
