PiegatoreSolidworks
It doesn't work for me, too.
I have a 32bit version, maybe the only thing different from you...
to me your file doesn't make a mistake.... then. .
Yes, the "problematic" is that, the profile and way to run it as well.
just opened your file is fine, everything regular. but if I enter into a sketch and define it or change a relationship, on the return part jumps out the notice and misses a fold.
after a "random" series updated list of items and reconstructions return to place, but if I try again to change something it turns again daccapo.
if I model a new part starting from your sketch (copy and paste) the error gives it to me immediately and I solve only suspending and reactivating that missing fold. . It remains the fact that with subsequent modifications to the sketch you will hang again and I have to remake all the correction procedure.
Okay, I'm at sp 0.0, but it's not a justification since it's an old feature that always worked very well. to you does not mai Do you?
What's wrong with you?
that done by me before the corrections:View attachment 22047 how do you open it/see?
and related pictures:View attachment 22048View attachment 22049Hello
marco
If we want to make it difficult to say that at least I'm a little busy......swx & "logical"?? ?
...make the flange at 90° instead of 45° and... no mistake... ?
Now I try again at 45° and tomorrow I try to re-ri-do the section on the pc in the office, maybe I also unload the sp4 ... indeed I see that it is "sp4 ev"?? ? then no, thank you, I wait for the sp4.0
correction: at home 2011 x32 sp3.0 and only after 1000 updates... 2011 x64 sp3.0. . .
;p... non difendo a sword drawn
hello and thanks x the interest,I think it's weird.
If you want to post your file maybe I try...
I have the version 2011 x64 sp. 2.0 ...
Let me know if you solved it.
I took that tape... I liked a mess of the vomero accident and the fight san gennaro vs sant' ambrogio... is vverooo.... :biggrin:correction: at home 2011 x32 sp3.0 and only after 1000 updates
in office 2011 x64 sp3.0 and zero problems.
fold:
that it is logical for a thiefist: Okay.
that it is logical x swx let you make folds of more than 78° but not lower: no (to reach 90° the sheet will have to pass for 45° and for the 78° ... logical... or not? )
that it is logical that swx in this case do not propose anything to you: I'm not... (I'm told that if you think otherwise...).
sp4 / sp4ev: my bread task gave me as present the s4 ev, only entering the site swx I see that from 17/06/11 is also downloadable the sp.4 (that I am downloading) :smile:
tried on a ws of the 32-bit xp and solidworks 2011 sp 0... no problem.... in fact. me with xp 32.
Marco: :
I always start with making clarifications.that it is logical x swx let you make folds of more than 78° but not lower: no (to reach 90° the sheet will have to pass for 45° and for the 78° ... logical... or not? )
Hi, mike.I quote you for sympathy.... :smile:
@reggio, can you post the file I try to open it with my pc?
Thank you...:finger:
ps: I find that the 2011 version is very stable and performing, Monday I will update
the various clients at sp 4, I have already created the administrative image Saturday.
a bug I had found in the sheets was fixed in sp 3 ( error in factor k, while changing it did not update all folds with the function "sheet converts").
I had discussed it in another post and also soliduser had found the bug.
For the rest.... never more trouble... apart from multibody sheets I only create in cases
"disperated" and cases where the number of components is easily manageable.
Everything's okay.
Hello, Reggio,correction: at home 2011 x32 sp3.0 and only after 1000 updates
fold:
try to manage 15-20 positions in multibody... Maybe they look like each other. . .Hi, mike.
I used multibody plates to make some record time hoppers and found them in place. What's the matter with you?
:smile: pant pant .. I can't fight at all, so I summarize with this cheerful tutorial:Hello, Reggio,
This time we're all on you, huh?
...after the recent swx apology with "extracted sword" with triple praise, double commendation and glorification you had not officially lost the right to complain? ;apart from frequent bugs ... registry is absent.
lost the body... bald. . .
I had to give up. . sin.:frown:
you made me die... nice post!!! :biggrin::smile: pant pant .. I can't fight at all, so I summarize with this cheerful tutorial:
develop a sheet with more than 4 folds with swx.1) acquires swx (better the version "super enterprise xxl 2011 subuteo")
2) Do all courses that put your dealer back
3) buy a decent workstation (or at the ksp a cape canaveral store, or a 32-bit xp ws)
4) five-year internship in Ticino workshop
5) Preventive verification of the register
6) preventive formatting and reinstallation of swx "super enterprise xxl 2011 subuteo"
7) go to the temple of zeus to the cloth for the breadcrumbs of swx
8) if possible prefer "basic flue" + tabs, if it is not possible to try to track the profile of the sheet, but first update to the next sp. . .
ps: in case of zero-thick cuts, if without high-locate knowledge, it was useless to think "it was to press "change the flange profile" and to shorten the outer edges by 1 mm." you will be answered that "the sketch is valid" (sometimes it will add dazzling pernacchie...) and you will stay at the starting point, so much so it is worth immediately applying n°2 hand brushes and raise a glory anthem to the swx programmers (with particular praise to those of the swx x32 room).
ps2: confuse warnings with errors, and above all try to never have any.
In fact, for the development of the loot, I went on with x64 and at home (x32) I try to trick myself* of the error still unresolved, for the fold to 45° I applied 2 hand slits.
*so I will probably be redeemed by solouser for having "launched" the rock and left the unresolved argument... but alas must proceed with the project.. .
I hope I have "satisfied" all, good cad to all
ot: the "must" for me is azz holidays: unsurpassed
hi reggio, no I'm here to say that he never has bachi or that it's all simple. the problem is that "it's a common bad." If you try more cads you'll notice that you're on the same wave line.:smile: pant pant .. I can't fight at all, so I summarize with this cheerful tutorial:
hi, we could almost say that the problem is detectable only on x32 and until sp3.... As soon as I have 1 moment I unload the sp4 x32 and try to update, if I solve myself, I would say that it can be confirmed.hi reggio I tried to open the file and it gives me no mistake.
use sw 2011 sp.4 win 32
I tried to change the flange inclination from 20° to 80 degrees and no error.
If I can help you ask.
Greetings to all.
