reggio
it was enough to press "change the flange profile" and shorten the outer edges by 1 mm.
...:redface: I must correct myself, in reality when it appears "the sketch is valid" is the time to approach the sketch and drag, after a couple of attempts, I too managed. . .ps: in case of zero-thick cuts, if without high-locate knowledge, it was useless to think "it was to press "change the flange profile" and to shorten the outer edges by 1 mm." you will be answered that "the sketch is valid" (sometimes it will also add dazzling pernacchie. . . )
..from this video I learned that it would be better to use the function shown between the min 2.54 and 3.09 which at one stroke only allows to perform"I don't know how to die"
- I'll break it.
- the fold
- the discharge (so you don't die...:biggrin
Of course, they had integrated the function that performs the discharge also in the "flangia of the edge" would certainly be better :wink:
