PierArg
I am a and b...for example in this case the quotas 30 and 40 refer to points a and b of the upper or wrong view?
However.... if as I understand you are doing mechanical engineering maybe it is better that you start making friends with drawing, quotas, tolerances etc., regardless of the goodness or not of the board that give you to doI also agree with this.
I am not and I will never be a top to interpret the quotas (it will be because the drawing exam since the trianal I took it on....groppone) however....
even when I was doing the university I remember that 70% of my "colleges" had a reluctance to the drawing.However.... if as I understand you are doing mechanical engineering maybe it is better that you start making friends with drawing, quotas, tolerances etc., regardless of the goodness or not of the board that give you to do
I think he's wrong.That's what I did.
I must say, however, that I have put a couple of "eye" constraints like odds.
in practice the part in red was not all defined so I put a random quota and then I put horizontality between points 1e2;3e4.
considerations in aid? !
Thank you so much again!
even in my opinion must keep the thickness constant.I think he's wrong.
the thickness is constant to 8 mm so you have to quota even the inclined segments
putting 8 mm thick and you will see that the points will be positioned properly.
I watched him quickly, huh?considerations in aid? !
I make the reasoning that if I see the piece from the outside, as depicted, the odds will be related to the geometry that "sees" and not on the hidden one.:smile:even in my opinion must keep the thickness constant.
---I wonder if the two quotas 30 and 40 of the lower view, which refer to the inclined segments of the diameter change, are referred to inside or outside; the measurements change...
Those are outside. for the inside there is the other view "in section" that indicates that 33... :smile: in this case I agree that those quotas are thrown there definitely to the cacchio:biggrin:. But you get there (ok, now you will tell me that I am an old "tope by tecnigraph" :tongueI wonder if the two quotas 30 and 40 of the view below... are reported inside or outside. . .
According to me, the 10 indicates the rise between the two lower floors.Good morning, everyone.
I'm still sorry to disturb you, but I think I have serious problems (personal) in interpreting quotas.
I have to realize the piece in figure (easy for the truth) but I have problems of interpretation of the quota (and maybe this is my biggest problem). I'll explain better.
1. I should make that cast in the shape of arc of radius 16 side circle; I would like to know if the red distance 1 is equal to the radius of the arc as if it were then adding the quotas 4 and 3 I do not find myself with the total quota of 64.
2. I have to realize the internal excavation in the shape of a circle arc (quota 2 red in figure) and vabbè knowing the previous quotas I can realize it totally by binding the sketch.
3.discussed but the quota 5 in red that is to indicate? ? ?
thank you all for the attention!
Have a good day!
Exactly, I was about to write the same thing!:finger:According to me, the 10 indicates the rise between the two lower floors.
the only share that could confuse you is the 38-25=13 which is the height where the r41 radius endsactually could be, even because otherwise that 16 would not be right to "exist".
I think I'm ignorant of interpreting quotas or at least these drawings are made a little miserable, so much so that the other quotas mentioned above I haven't understood them so sincerely.
Thank you very much for the tip!
1)Yes, it is the ray quota so the 16 is correct. do not get screwed, the 64 does not end at 10 (3) but continues for another 28 mm that you do not see anywhere.Good morning, everyone.
Have a good day!
my question is: what do you study at school if you do not understand these simpleI honestly say that you might be right perfectly but a drawing like what I posted can be a drawing given to the exam?
sec me the boys (I included to 320%) I would confuse myself safe!!
